Home :: Tools, Starters & Chargers :: Tools :: Flywheel Puller Removal Tool
This flywheel puller is designed for those who don't want to use the "knocker" method to remove their flywheel.
Works with:
  • ALL ARC Flywheels with Steel Adjustable Timing Hubs
  • PVL flywheel for clone
  • Raceseng Flywheels
  • ARC flywheels that do not have the steel center hub will be drilled and tapped for this puller as a running change in 2013.
  • WILL NOT ever work with our "ultra-light" flywheels such as the 6602 as they cannot be drilled and tapped to use this puller.
To use, install the threaded rods into clean and lubricated puller holes on hub or flywheel face.  Be sure to thread the rods in fully.  Slide the puller block over the threaded rods and screw the nuts down evenly.  Tighten the nuts evenly back and forth in 1/2 turn increments until the flywheel pulls off.  Stubborn flywheels may require that you hit the center of the puller block with a hammer once significant pressure is applied by tightening the nuts.  Be careful not to strike the threaded rods (use a spacer if necessary) and NEVER hit the flywheel itself with a hammer.
Heat as low as 300° will damage the rare-earth magnet in flywheels, so don't use a torch!
Puller has 8 holes drilled - 4 each side.  Two studs with 5/16 thread are supplied - these are screwed into the 5/16 threaded holes in US Based billet/aluminium flywheel hubs (suits our Stage 1 and Stage 2 flywheels).  It can be oriented to offer the following threaded hole spacing (measurements are hole-centre to hole-centre):
~31mm
~37mm
~44mm
~50mm
~57mm
~63mm
~70mm
SKU TEFPA1
$279.00
