Home :: Racing Simulator Parts & Retro Computing :: Fanatec ClubSport Pedals V3 (Display Stock)
UNUSED but fitted - display model.  Has been fitted for display and photo purposes then packed back in the original packaging.
Advanced Technology
Nothing will make you faster than a set of good pedals. We are using the latest and most advanced technology to give you an advantage.
90 kg Load Cell (adjustable)90 kg Load Cell (adjustable)
The custom made load cell is extremely durable and much more precise as the one in V2. You can apply a realistic and strong pressure and precisely control the brake with muscle tension just like in a real car.
Contactless Hall Sensors with 12 bit resolutionContactless Hall Sensors with 12 bit resolution
​The electronics have been completely revised and the magnetic hall sensors of the gas and clutch feature 4x the resolution of the V2 pedals. Each axis can be calibrated in the wheel or in the driver.
  Advanced Technology
Maximum Adjustability
​There are countless ways to adjust these pedals according to your racing style and ergonomics.
New Pedal PlatesNew Pedal Plates
The new D-shape pedal plates and the new pedal extensions now allow to adjust the angle of the pedal plate and the angle of the whole pedal arm.
Adjustable Brake StiffnessAdjustable Brake Stiffness
The completely new design of the brake allows to adjust the stiffness and travel of the brake pedal without using any tools.
Proven Design
The third generation of the ClubSport pedals is still using the simple but proven design of it's legendary predecessors.
Full metal constructionFull metal construction
The complete pedal set is made of fine CNC-machined aluminum along with strong steel axis.
Vibration Feedback pedalsVibration Feedback pedals
The new vibration motor on the gas pedal can be used by games to indicate if you lose grip and should power down. The second motor on the brake could warn you if you brake too hard and lock the tyres.
Proven Design
Features
High resolution pedals with magnetic and contactless sensors on gas and clutch for a long life and maximum performance
Pressure sensitive brake with custom made 90 kg load cell sensor
Adjustable brake stiffness and travel without tools
12bit resolution (4096 values) on all axis
Alternative D-shape race plates in curved design. Ideal for standing pedals
Pedal extension to adjust the angle of the pedal plate and to change the angle of the whole pedal arm
Brake sensitivity can be adjusted through the tuning menu of the wheel and during the race
Vibration motor on throttle pedal indicates rear wheel spin and oversteer (control by games is possible via Fanatec Wheel SDK)
Vibration motor on brake pedal to simulate ABS and indicate locking tires (controlled by Fanatec wheels: Compatible to all games. Dynamic control by games is possible via Fanatec Wheel SDK)
Design of the gas pedal allows quick exchange of the springs. Two springs with different strength are included
Optional damper kit for gas and brake. The hyraulic dampening resistance can easily be adjusted with a knob
Full multi platform compatibility, depending solely on the platform compatibilities of the connected Wheel Base/Racing Wheel
Full metal construction of CNC-machined aluminum
Ultimate adjustability: Position of pedal plates in all directions, angle, spring strength at throttle, brake sensitivity, brake travel
Compatible to the colour kits to allow perfect optical customisation
Compatibility
Peripherals:
Compatible to any Fanatec Wheel Base or Racing Wheel with RJ12 Pedals connector. To connect Fanatec Wheels with PS/2 Pedal Socket, you need the additional PS/2 to RJ12 cable.
Compatible to ClubSport Pedals V3 Brake Performance Kit
Compatible to ClubSport Pedals V3 Damper Kit (throttle and brake pedal)
Dedicated plug for the ClubSport Handbrake
The pedals are not compatible to the ClubSport USB Adapter. Please use the included USB connector (PC only).
Platforms:
PC:
If you connect it to a Fanatec Wheel Base / Racing Wheel it will be compatible to all racing games. For that case, please check the compatibility details on the product page of the connected product.
It will work with any racing wheel, also of​ any other brand (Logitech, Thrustmaster, etc), if the pedals are connected to PC via USB and if the game supports a second controller. ​E.g. these PC games support a second USB controller:
iRacing
Assetto Corsa
Project Cars
GTR 2
Race 07
rFactor
Live for Speed
...and many others
Consoles: This pedal set can be used on gaming consoles, if connected through a Fanatec Wheel Base / Racing Wheel. Please check the information on the product page of the Fanatec product through which they will be connected to the console. It will not work on consoles using the direct USB Connection or a ClubSport USB Adapter.
Special Notes
Please note that the vibration function on gas and brake is not supported by all games. On PC it can be implemented with plug ins to our driver / third party software if the games sends the telemetry data.
Max resolution depending on the connection:
through PWT / PWTS / CSR / CSR Elite wheel: 8 bit (256 values) on all axes
through CSW B V1 / CSW B V2 / CS WB V2.5 / CSL E WB / CSL E RW PS4: 12 bit (4096 values) on all axes
USB direct connection (PC): 12 bit (4096 values) on all axes
Packaging Details
Size (L x W x H) : 43.00cm x 28.00cm x 43.00cm
Weight: 7.94kg
Volume weight: 10.35kg
What's included
ClubSport Pedals V3
3x Pedal Extensions
3x D-shape pedal plates
1x Strong spring throttle (black)
1x Strong spring clutch (black)
1x RJ12 connection cable (150cm)
1x USB connection cable (180cm)
1x Lithium grease bottle
1x Quick Guide
Display Model
SKU SIMFPE
