Home :: Engines, Carbs & Parts :: Engines :: Engine Side Cover Studs Stud set (6 Pack + 2x Solid Dowels) CPR Race premium strength GX270 GX390 Predator 420
Increased strength side cover studs (CPR Performance).  Designed for extreme racing engines.
Pack of 6pcs studs + bonus 2x Solid Dowels - full set
If you're having issues with sidecover bolts coming loose and losing oil at high rpm on your engine, this is what you need.
FITS:  GX270 GX390 Predator 420
Lubricate all studs before fitment using engine oil or WD40.
Remove dowels from side-cover and install supplied solid dowels in their place.
Install nuts & washers, torque to 20ft lbs.
It is recommended to use loc-tite on sidecover studs.
HeadTearDownGuide
SKU ESCS39
