Home :: Engines, Carbs & Parts :: Engines :: Engine Side Cover Studs Stud set (6 Pack + 2x Solid Dowels) CPR Race premium strength GX200 GX160
Increased strength side cover studs (CPR Performance).  Designed for extreme racing engines.
Pack of 6pcs studs + bonus 2x Solid Dowels - full set
If you're having issues with sidecover bolts coming loose and losing oil at high rpm on your GX200 or clone, this is what you need.
Lubricate all studs before fitment using engine oil or WD40.
Remove dowels from side-cover and install supplied solid dowels in their place.
Install nuts & washers, torque to 20ft lbs.
It is recommended to use loc-tite on sidecover studs.
HeadTearDownGuide
SKU ESCS65
