Home :: Engines, Carbs & Parts :: Crank Case & Bottom End :: GX160 GX200 Predator/Torini Bottom End Parts :: Engine Flywheel Cover for Starter Access - Aluminium Suit GX200
*NOTE: THIS NEW MODEL DOES NOT HAVE THE ARC BRANDING/LOGO*
Aluminium Flywheel Cover
This cover is to be fitted over the empty hole in a 4-stroke engine flywheel shroud when the pull start is removed.
FIts most 4-Stroke engines up to GX200 (does not fit GX270+ without modification)
Outside Diameter 177mm
3-hole (larger outside mounting holes) pcd Diameter 160mm
4-hole (smaller outside mounting holes) pcd Diameter 162mm
Inside Diameter 49mm
SKU EPSCN1
