Home :: Washers, Spacers, Springs, Nuts & Bolts :: Bolts & Nuts :: 10mm :: Go Kart Engine Mount Stopper 10mm Nylon Head Bolt M10 90mm long High Tensile NEW with Nut and Locknut
BRAND NEW Go Kart Nylon Head head Bolt M10 90mm long High Tensile NEW with Nut and Locknut
M10.  90mm Long.  Nylon Head.
Complete set
ELIMINATES ENGINE MOUNT CREEP WHICH CAN CAUSE NON-TENSIONED CHAINS AND DAMAGE
This is designed to be fitted through either a cylinder welded to the frame, or through a nut/cylinder/hole in a flat bar across the two bearing hanger brackets behind the engine mount.  See picture for mounting example.
SKU BES10S
