Home :: Engines, Carbs & Parts :: Mounts :: Engine Mount (GX200) 32mm Tube 88mm Centre to Centre Rails (or 90mm up to 30mm tubing) - suits CPR Chassis (ROSEMARYSPECIAL)
Our new Billet engine mounts have arrived!
Designed for Four Stroke karts and pre-drilled to suit GX200/160 and clone engines.   Plate is large enough to accomodate larger engines or other base plate configurations.
Suit 28-32mm Chassis rails (88mm chassis rail spacing can use 28-32mm tubes, or 90mm chassis rail spacing can accomodate 28-30mm tubes)
Distance between chassis rails (Centre to Centre) = 88mm (can also be used for 90mm spacing but max of 30mm tubing.
Complete top and bottom brackets with bolts as pictured.
Suits CPR Chassis
SKU EMTC8832_ROSEMARYSPECIAL
