Home :: Engines, Carbs & Parts :: Mounts :: Engine Mount Billet Fully Adjustable Centre to Centre Rails Suit GX270 GX390 GX420 (Predator 420)
Fully Adjustable Anodised Billet engine mounting system.  (lateral position adjustment)
15 degree angled.
Suits 90 or 92mm rail centre to centre and 28-32mm tubes.
The perfect mount for switching to 4-stroke engines (threaded holes designed for Honda GX270, GX390, GX420 and clone engines as well as 420 Predator
Complete top, middle and bottom brackets with all required bolts.
(*NOTE, 3-slot unit pictured for reference, this model only has 2 slots)
*PICTURE WITH DIMENSIONS IS ACTUALLY A DIFFERENT MODEL - FOR REFERENCE PURPOSES ONLY*
Dimensions:
A (Side edge to centre outer slot edge) - ~30mm
B (TOP AND BOTTOM Slot Length) - ~60mm
C (TOP AND BOTTOM Slot edge to other side of plate edge) - ~35mm
Total width of top plate - ~127mm
F (Top Plate length) - ~228mm
Compatible engine bolt spacing:  73mm Wide, or 85mm Wide.   195mm Long (ie: 195 x 73mm, or 195 x 85mm)
SKU EMTN39
