Home :: Engines, Carbs & Parts :: Mounts :: Engine Mount 4-stroke Conversion Adapter Adaptor torque plate - Convert 2-stroke mounts to 4-stroke engines (Silver, not black as pictured)
*NOTE: Black pictured but currently supplied in Silver*
*NOTE: We recommend using a torque plate/adapter like this to ensure the maximum reliablity for modified motors.  Performance modified engines require strengthening of the crank-case by a solid plate to ensure maximum reliability and to avoid cracking of the case.
Our new Billet engine mount adapters have arrived!
Designed for Four Stroke karts and pre-drilled to suit GX200/160 and clone engines.   Plate is large enough to accomodate larger engines or other base plate configurations
Plate dimensions = 240mm (L) x 160mm (W) x 16mm (Thick)
GX200 base is 162mm x 78mm hole centre to hole centre.  On our plates the hole size is approx 8.9mm to suit M8.
Simply drill 4 holes for your existing engine mount and sandwich between your existing mount and the engine.  Perfect for converting 2-stroke karts to 4-stroke.
Works with all of our 2-stroke mounts.
SKU EMAPC1
