Home :: Engines, Carbs & Parts :: Mounts :: Engine Mount 32mm Tube 90mm Centre to Centre Rails
Designed for Two Stroke karts such as Yamaha KT engines, this mount can also serve as a perfect base for a Honda Clone adapter plate.  Just drill 4 holes in a flat piece of plate to suit this mount, and another 4 holes for your alternative engine (or honda clone)
Suit 30-32mm Chassis rails.
Distance between chassis rails (Centre to Centre) = 90mm
Complete top and bottom brackets with bolts.
SKU EMTS9032
