ECSC01 Crankshaft review
These are a stock 3/4" shaft crankshaft for GX200 clones.
they are perfect for converting 6.5hp clone engines that have the wrong type of crank.
I have a pump engine that came with a 3/4" shaft with no keyway and external thread. i puchased this crank from Paul, removed the old crank and put this in. perfect fit.
these are great for converting any other 6.5hp clone engine that does not have the 3/4" output shaft with the 1/4" keyway required for clutches and T.A.V's.
You can buy the genuine crank, but these work great and are 1/3 the price.
I'd suggest buy a seal and gasket kit at the same time, but you should be ok with just the case gasket.
