Home :: Tachos, Laptimers & Gauges :: Temperature Gauges :: Cylinder Head Temperature Replacement Sensor suit TTEMP1 CPR Temp Gauge (Short)
*NOTE: THIS ITEM FITS THE OLDER TTEMP1 GAUGE, NOT THE NEW TTEMPGT GAUGE WHICH WE STARTED SELLING IN AUGUST 2020. If you bought an older gauge, then this item will fit your gauge*
Replacement lead to suit CPR GT Temp Gauge.
Lead length (110cm total when fitted to Gauge)
Sensor ID = 14mm
Designed for go karts.
CHTGuide
SKU TTESCHS
