Home :: Chassis Parts :: Crash bars and linkages :: Crash Bar Rear Mounting Kit (Bracket PAIR) Genuine CPR suit CPR Rear Plastic Bumper Bar Brackets (PSRC1)
Genuine CPR Rear Crash bar mount Kit.
Mount a rear crash bar to a tube chassis using the existing tube mount bolts hoding a standard chrome bar on (remove chrome bar) using these two mounts.  ID of the bracket tube = ~21mm.  If your crashbar tube (where it fits over the bushes on your existing crashbar bolts) is approximately 21mm then these brackets will mount directly onto your crash bar mounting rubbers/bolts without modification to the bushes.  If your crash bar tube is smaller ID then you will need to turn down or file down your bushes to suit.
Genuine CPR Mount to suit CPR rear plastic bumper bars.
Fits standard race karts.
SKU PRBMC1
Rear Bumper Bar suit PSCC1 New-Style Plastics Kit
Crash Bar Rear Mounting Bolts suit 28mm Chassis
Rear Bumper Bar suit PSCC1 New-Style Plastics Kit Crash Bar Rear Mounting Bolts suit 28mm Chassis
$139.00
$69.90
Crash Bar Rear Mounting Bolts suit 30mm Chassis
Crash Bar Rear Mounting Bolts suit 32mm Chassis
Crash Bar Rear Mounting Bolts suit 30mm Chassis Crash Bar Rear Mounting Bolts suit 32mm Chassis
$69.90
$69.90
Bush Set to suit rear crash bar bumper 10mm ID 20mm OD 27.4mm Chassis Tube ID (Can be linished or filed smaller) suits CPR PRBMC1 Mount Kit
