Home :: Engines, Carbs & Parts :: Crankshaft (OEM CPR High Quality) suit GX200 Clone including CPR engines (3/4" 19.05mm outlput shaft)
Stock Clone Crankshaft.
This is the OEM replacement component for our high quality engines.  Our crankshafts are known to be balanced to a much higher quality than standard 'cheap' clones and are the perfect upgrade if yours has damage, has the wrong output fitting/size or you want to build a performance engine with less vibration.
Output shaft size 3/4" (19.05mm) fits all standard clutches.
58%
SKU ECSC01
