Home :: Engines, Carbs & Parts :: Crankshaft (Stroker Clone suits GX200 Rod & Flywheel) suit GX200 Clone including CPR engines (3/4" outlput shaft) add 4cc
Stroker (+0.40) Clone Crankshaft.
+.040 Stroker Crank for GX200 style engines and clones
Stroke is 2.163-2.173"
(usually most GX200's run about .040 in the hole so generally this will work fine with stock piston height - or use a thicker head gasket if required)
Approx 200cc. with stock bore or 212cc. with 70mm Bore.
Uses the Honda/Clone connecting rods and flywheels.
Output shaft size 3/4" (19.05mm) fits all standard clutches.
Output shaft length approx 57mm (to flange)
Can also be used as a stock replacement in Predators if flywheel and rod is changed to GX200 style.
21%
SKU ECSSTN2
