Home :: Engines, Carbs & Parts :: Crankshaft Short Shaft (HALF-SHAFT RIGHT SIDE) suit KT100S (PRE-ORDER - not in stock)
PRE-ORDER ITEM - NOT IN STOCK - TAKES AROUND 1 WEEK FROM DAY OF ORDER AND PAYMENT TO DISPATCH
Stock KT100S Crankshaft.
This is the Short Shaft OEM replacement Half Shaft for KT100S engines - RIght Side - This is the side your sprocket/clutch connects to.  Can be fitted to all KT100S left side crankshaft halves (ie: Convert long shaft to short shaft)
This is the half shaft only - does not include crank pin or plugs or any other assoicated hardware.
SKU ECHSKS_PREORDER
