Home :: Clutches :: Crankshaft Retainer Washer (suit GX200)
3mm thick
29mm OD
8mm ID
This is the correct, thick washer to retain the clutch on a 3/4" (19mm) or 5/8" (16mm) crankshaft.
Thin washers will buckle over time, allowing the retainer bolt to unscrew and will end with the clutch falling off the shaft if you're not careful.  This causes significant damage to the drivetrain and sometimes the crankshaft.
The washer can be used with most  other crankshaft sizes as well ncluding 1" but will need the centre drilled if using a 10mm bolt.
NEW.  Click the condition meter to learn more about used items.
SKU M8WSHROD
