Home :: Tachos, Laptimers & Gauges :: Temperature Gauges :: Coolant (Water) Temperature Replacement Sensor suit TTEMPGT CPR Temp Gauge
*NOTE: THIS ITEM FITS THE NEWER GT GAUGE WITH A WHITE CONNECTOR, NOT THE OLD TTEMP1 GAUGE WITH A BLACK CONNECTOR SOLD UP UNTIL AUGUST 2020. If you bought a gauge after August 2020, then this item will fit your gauge*
Replacement lead to suit CPR  GT (GT2) Temp Gauge.
1/8 BSP sensor - fits Rotax Max 125
Lead length (160cm total when fitted to Gauge)
Designed for go karts.
CHTGuide
SKU TTESWGT
