Home :: Tachos, Laptimers & Gauges :: Tachos :: Coolant (Water) Temperature Gauge GT CPR 2 or 4-Stroke with Max Temp Recall - Easy To Read Large Display, Backlight, Replaceable Battery, Temp Alert
Awesome new budget-focussed coolant/water temp gauge - no longer do you need to pay $500 to save your engine from costly overheating damage.
When running a high performance engine, temperature can build up too fast to feel when you're rushing around a track at breakneck speed - you need a reliable solution to alert you to overheating.  Overheating an water cooled engine can quickly result in melted pistons, damaged rings and ruined cylinders - lots of costly damage you could avoid by installing this awesome new piece of equipment!
NEW Front-Mounted Buttons RESETTABLE MAX TEMP FUNCTION!  PLUS SETTABLE TEMPERATURE ALERT!
This model suits both 2 & 4 stroke karts.
COMPLETE  EVERYTHING you need to bolt-on and go - including water temperature sensor - simply replace an existing sensor or drill and tap a 1/8 inch BSP thread (same as race-kart brake fittings) in a manifold, bend, or other location on your water cooled engine and install.
1x up to 300 degrees C Temp Gauge with TEMP ALERT, MAX-TEMP Recall.
1x Backlight system
1x Sensor with clip/connector
Sensor line length 160cm
1x Battery
1x Instructions Set
LARGE 5 digit LCD screen
BACKLIGHT
Minus 20C to 300C sensitivity
OVER-TEMP ALERT
Maximum Temp Recall
Current Temp
waterproof level IP65
2-STROKE AND 4-STROKE AIR COOLED COMPATIBLE!
If you've got a water cooled 2 or 4 stroke engine, and you've seized it due to lean-out you'll know just how quickly that can happen - in the course of one long straight often. If you're running speedway it's an even bigger problem with revs constantly high.
Rebuilding an engine due to lean-out and melted pistons can cost upwards of $500 depending on who's doing it for you - parts run $200-$300 easily and that's if you can save the bore.
THIS GAUGE WILL SAVE YOU!
- TEMP LIMIT ALERT - User Settable
- LARGE BACKLIT DISPLAY
- MAX TEMP RECALL
- REPLACABLE BATTERY
- WEATHER PROOF
- INCLUDED 1/8" BSP TEMP SENSOR
With it's unique temperature alert, backlight and Maximum Temp Recall you'll be in the know at all times - and you can keep a close eye on what your engine is doing while you're driving.
You can even tune your engine using the temp gauge!
The other options for temp gauges on the market are costing in excess of $500 - but with this neat little unit you'll be paying less than $100 to be fully protected!
Is it really worth not having a temp gauge at this price?
Designed for go karts.
CHTGuide
SKU TTEMPW
Regular price: $107.27
Coolant (Water) Temperature Replacement Sensor suit GT CPR Temp Gauge
$39.00
