Home :: Engines, Carbs & Parts :: Pistons & Conrods :: Conrod for Honda GX200 & Honda Clone Billet (Stroker)
Billet Rod ARC Pro Series featuring the industries only forced oil dipper for superior oiling to the crank pin. CNC machined from 7075 T-651 aluminum and are designed to withstand the rigors of today's high horsepower kart engines. These rods boast advanced oiling design and high strength ARP rod bolts. These are simply the best rods money can buy. Rod includes bearing and bolts.
Oil gap clearance < 0.004" and greater than 0.002"
Cap bolt torques ~ 150in/lbs (moly lube on threads) or ~170in/lbs (oil on threads)
PLEASE NOTE: These are US designed and have imperial bolt heads.
Suits Honda GX200 & Clone Engines.
********** NOTE: THIS IS A STROKER ROD - Designed to suit a billet stroker crank - Rod 3.625" GX 200 or 196cc Clone Stroker ***********
INCLUDES BEARING - not pictured.
Looking for an installation manual?  You can download it by CLICKING HERE
ConRodGuide
SKU CRG2ST
Bearing - ARC Conrod replacement bearing (Suits Stroker Crank Conrod CRG2ST)
Rod Bearing clearance measuring tape guage plastigage 150mm length
Bearing - ARC Conrod replacement bearing (Suits Stroker Crank Conrod CRG2ST) Rod Bearing clearance measuring tape guage plastigage 150mm length
$39.95
$8.95
