Home :: Engines, Carbs & Parts :: Pistons & Conrods :: Conrod for Honda GX200 & Honda Clone Billet (+0.020) (also suits predator flat-top piston) Genuine ARC
Billet Rod ARC Pro Series featuring the industries only forced oil dipper for superior oiling to the crank pin. CNC machined from 7075 T-651 aluminum and are designed to withstand the rigors of today's high horsepower kart engines. These rods boast advanced oiling design and high strength ARP rod bolts. These are simply the best rods money can buy. Rod includes bearing and bolts.
Oil gap clearance < 0.004" and greater than 0.002"
Cap bolt torques ~ 150in/lbs (moly lube on threads) or ~170in/lbs (oil on threads)
PLEASE NOTE: These are US designed and have imperial bolt heads.
** THIS CONROD IS +0.020" longer in length. **
Suits Honda GX200 & Clone Engines running our Predator 70mm flat-top piston kit.
Suits 1.180inch crankshaft journal (29.97mm)
Replacement bearing available: ECBBM1
Looking for an installation manual?  You can download it by CLICKING HERE
ConRodGuide
SKU CRBARC2
Bearing - ARC Conrod replacement bearing GX200
Socket - Suit GX200 and Mitsubishi (Vangard) Billet Conrods 1/4inch Drive
Bearing - ARC Conrod replacement bearing GX200 Socket - Suit GX200 and Mitsubishi (Vangard) Billet Conrods 1/4inch Drive
$69.95
$19.95
Rod Bearing clearance measuring tape guage plastigage 150mm length
$8.95
