Home :: Hop Up Kits :: Complete Upgrade DIY Kit STAGE 1 for 4-BOLT valve cover 4-Stroke Engine GX200 LIFAN OHV 6.5hp 192cc Complete
RACE-SPEC UPGRADE KIT.
Convert your GX220 Honda Clone (6.5hp) to our STAGE 1 race-ready engine with this kit.
This kit contains all of the parts to convert a genuine Honda GX200 (or clone) to the same specification as our ENCLGT race engines.
*NOTE: Not all GX200 clones are of high enough quality to ensure reliable and smooth power output.  Installation of this kit does not improve any poor quality components (For example, poorly balanced crankshafts or camshafts with low quality lobes) - it is recommended to use a genuine Honda GX200 for the upgrade, but clones will work - your mileage will vary.
INCREASE HP OUTPUT SIGNIFICANTLY AND SAFELY.
Complete upgrade pack to suit our LIFAN 6.5HP honda clone engines.
This kit replaces Air Intake system, upgrades the fuel system to an external tank and high flow fuel pump, upgrades exhaust system and includes all springs and connectors necessary for a complete change-over and external removal of governor.  Includes 18lb valve springs rev kit, pair of chromoly pushrods, aluminium flywheel, 98 Fuel Jet, ARC Billet connecting rod - everything you need to get your standard clone engine competitive at the track.  This is the exact same kit we use to build our STAGE 1 Engine which is competitive at IPSWICH in QLD.   Also includes polished aluminium professionally welded deflector and mount plates.  Your engine will look fantastic after this upgrade!
Also comes complete with head gasket and crank case gaskets for certainty when rebuilding.
This kit is to suit the 4-Bolt valve cover version of the GX200 clone, if you have a 5-bolt style valve cover you will need the 5 bolt version instead.  You can check your version by
Contents:
- Performance Air Filter
- Performance Venturi Adaptor
- Remote Throttle Linkage Kit
- Billet Top Fuel Pump mounting Plate
- Billet Chain Guard Side Plate
- Fuel Line & Tubes
- External Fuel Pump
- Sports Muffler
- Vacuum source sandwich plate for manifold to power fuel pump
- Fuel Jet - 88
- 26lb Valve Spring Rev Kit (complete with additional Lash cap and retainer)
- Chromoly Push Rod set (2pcs)
- ARC Billet Con-rod
- Aluminium Flywheel
- 4 Bolt head style crank-case gasket
- Replacement Head gasket
Get more power, easily!
Complete Brand New Upgrade Kit to suit 4-Stroke Engine LIFAN 6.5hp OHV 192cc (Honda Clone)
SKU EUGKS1_4B
Regular price: $2014.36
Price with FREE DELIVERY: $719.00
