Home :: Hop Up Kits :: Complete Upgrade DIY Kit STAGE 2 for 4-BOLT valve cover 4-Stroke Engine GX200 / LIFAN OHV 6.5hp 192cc Complete
RACE-SPEC UPGRADE KIT.
PRODUCES BETWEEN 14-18hp
Convert your GX220 Honda Clone (6.5hp) to our STAGE 2 race-ready engine with this kit.
INCREASE HP OUTPUT SIGNIFICANTLY AND SAFELY.
Complete upgrade pack to suit our LIFAN 6.5HP honda clone engines.
This kit replaces Air Intake system, upgrades the fuel system to an external tank and high flow fuel pump, upgrades exhaust system and includes all springs and connectors necessary for a complete change-over and external removal of governor.  Rev Safely and strong to 7000+rpm with our 24lb valve springs rev kit, pair of chromoly pushrods, aluminium flywheel, 98 Fuel Jet, Stage 1 Mild-Race high torque camshaft, .650 Bored Genuine honda carburettor, Race engineered double re-inforced 1:1.3 ratio valve rockers, mild race ported replacement head, ARC Billet connecting rod, flat-top performance piston and ring set,  - everything you need to get your standard clone engine competitive at the track.  This is the exact same kit we use to build our STAGE 2 Engine which is winning races at IPSWICH in QLD.   Also includes polished aluminium professionally welded deflector and mount plates.  Your engine will look fantastic after this upgrade!
Also comes complete with head gasket and crank case gaskets for certainty when rebuilding.
This kit is to suit the 4-Bolt valve cover version of the GX200 clone, if you have a 5-bolt style valve cover you will need the 5 bolt version instead.
Contents:
- Performance Air Filter
- Performance Venturi Adaptor
- Remote Throttle Linkage Kit
- Billet Top Fuel Pump mounting Plate
- Billet Chain Guard Side Plate
- Fuel Line & Tubes
- External Fuel Pump
- Race Muffler
- Vacuum source sandwich plate for manifold to power fuel pump
- Fuel Jet - 98
- 24lb Valve Spring Rev Kit (complete)
- Stage 2 mild-race camshaft
- Chromoly Push Rod set (2pcs)
- Increased ratio 1:1.3 Re-inforced rocker arm pair
- ARC Billet Con-rod
- Aluminium Flywheel
- 4 Bolt head style crank-case gasket
- High flow mild race port replacement head
- Increased compression flat top piston and ring set
- .670 worked genuine honda carburettor
- Replacement Head gasket
Get more power, easily!
Complete Brand New Upgrade Kit to suit 4-Stroke Engine LIFAN 6.5hp OHV 192cc (Honda Clone)
SKU EUGKS2_1
Regular price: $2016.23
Price with FREE DELIVERY: $1470.00
