Home :: Engines, Carbs & Parts :: Engines :: Complete Rebuild Kit Set Stock Clone Suit Honda Clone GX200 ENCLST1 ENCLGT with 4-bolt Valve Cover includes Piston Rings Gaskets Conrod Seals Bearings
Complete gasket set to suit GX200.
1x OEM CPR stock conrod (may be removed from new engine)
1x OEM CPR stock piston (may be removed from new engine)
1x OEM CPR ring set to suit stock piston
1x Gudgeon (piston) pin
1x Pair of piston pin clips
2x Crankshaft bearings
2x Crankshaft seals
1x Exhaust Gasket
1x Valve stem seal (inlet valve)
1x Set of inlet (carb/insulator/head) gaskets (3pcs)
1x Valve/Rocker cover gasket
1x Head Gasket (68mm to suit GX200 - does not fit predator 212 engines)
1x Side Cover Gasket
FITS:  All CPR GX200 196cc engines.  All Honda GX160 & GX200 engines & Clone GX160 & GX200 engines.
HeadTearDownGuide
SKU ERSST1
Regular price: $188.41
Price with FREE DELIVERY: $149.00
