Home :: Plastics & Numbers :: Complete Plastic Plastics Sidepods Nosecone and Nassau Panel set (Includes Sidepod Bars - No Nassau Panel Bars)
*PLEASE NOTE: THIS ITEM CANNOT BE SHIPPED TO A PO BOX DUE TO IT BEING TOO BULKY FOR AUS POST
THIS KIT ALSO INCLUDES ONE PAIR OF SIDEPOD BARS, AND BOLTS TO FIT THE SIDEPODS!
*New Model complete plastics set.  Can be used for both 2 stroke and 4 stroke kart applications.
Suits newer model karts with straight (90degree perpendicular) sidepod bars.  Can be easily modified to suit older karts.
COMPLETE Kit.  Comes with Nosecone, Nassau Panel, and both sidepods.
Nosecone has detachable quick release bracket (pictured) which can be removed and replaced with old-style brackets if required.
Dimensions:
Nosecone - Maximum width (widest part to widest part) = 1050mm, Depth at front (mount section) =108mm, Width of front bar to suit = 300-500mm, Distance from Mount to rear of nosecone where it meets front wheels = Approx 102mm
Sidepods - Length = 600mm, Width(at centre) = 180mm, Height = 200mm,  Front cowling adds 95mm width to sidepod just behind front wheel.
Nassau - Height = 700mm (slots into front nosecone), width = 250mm (at mount point near steering wheel).
Dimensions of sidepod picture:
SA - distance from divet to edge of front of sidepod = 70mm
SB - distance from divet to front bolt hole centre = 35mm
SC - bolt hole centre to bolt hole centre = 457mm
SD - rear bolt hole centre to rear of pod = 55mm
SE - Total length of sidepod = 617mm
SF - distance from rear bolt hole centre to centre of divet (cutout for bar) = 75mm
Suits new model karts.  (perpendicular from front of kart, perpendicular from rear)
Dimensions of Sidepod Bars:
A - Distance between mounting bar points TUBE CENTRE TO TUBE CENTRE - 420mm (Bars run parallel to each other)
B - Length of long bar - 420mm
C+D - Length of short bar - 280mm
C - Distance from mouting tab (Centre of hole) to end of short bar - 210mm
D - Distance from mouting tab (Centre of hole) to front of bar - 60mm
E - Distance from centre of mounting tube to centre of upright (same for both sides) - 25mm
F - Distance from cetnre of upright tube to end of top bend ( more angled upright) - 80mm
G - Distance from before bend to before bend on top bar - 250mm
H - Distance from cetnre of upright tube to end of top bend (less angled upright) - 40mm
I - Height of upright (centre of tube to centre of tube) - 110mm
KT100ShaftGuide
SKU PSCC1_KIT_L
Regular price: $1302.32
Price with FREE DELIVERY: $381.00
