Home :: Wheel, Tyres & Front Hubs :: Rims :: Complete Go Kart Off Road Rims & Tyres REAR PAIR ONLY - NEW MODEL 3x50mm PCD FITS RACE KART HUBS
BRAND NEW PAIR OF REARS ONLY
These will bolt onto STANDARD RACE GO KART HUBS 3x 50mm PCD
This will provide approx 120mm additional diameter at the front and 100mm additional diameter at the rear compared to a normal senior race kart based on: Our off-road tyres are around 320-340mm in diameter depending on how much you inflate them. Generally, on a standard senior-size race kart with dry-slick rims and slick tyres you would normally be running about 220mm at the front and 240mm diameter at the rear. (Note, dry slicks are usually limited to a low inflation and this reduces ground clearance, so sometimes they may be even less).
REAR
5" Wide
6" Diameter RIms
Rim Holes are 78mm from each other centre-to-centre (3x78mm PCD)
Adaptor Holes are 3x50 PCD to suit standard race go kart hubs
13" Diameter Tyres fitted - 13x5.00-6
*PLEASE NOTE: The tyres on these rims are larger than the ones on the silver front rims.  The specification is the same, but the brand has a different sidewall height which makes these tyres about 1 inch larger in diameter.
Steel rim centres.
KIT INCLUDES
2x WHEELS
2x 3x50 to 3x78mm PCD Adaptors
All hardware required to connect them together
*PLEASE NOTE - The tyre size on these black wheels are the same specification as the silver wheels BUT THEY ARE LARGER IN DIAMETER by about an inch or so. This is purely because of the brand of tyres used. The tyres can be interchanged.
Designed for most brands off road karts.
SKU WSORNA
Regular price: $256.50
Price with FREE DELIVERY: $219.00
