Home :: Axles & Parts :: Complete GTR-RACE Series 50mm Axle Kit 12mm Ventillated Disc 8mm Keyway Black
PLEASE NOTE - THIS IS A NEW MODEL - the exact design of some of the components have changed from the main picture - please see the detailed images for the exact components in the kit.
COMPLETE 50mm AXLE ASSEMBLY including 12mm Ventillated Brake disc (with standardised 6-bolt race hub included).  EVERYTHING you need to bolt-on and go.  Includes ALL the nuts and bolts WITH ANODISED COUNTERSUNK WASHERS!
1x 50mm Anodised Brake Hub
1x 12mm Ventillated 208mm Brake Disc
1x 50mm Anodised Sprocket Carrier/Hub
2x 50mm Low Friction Sealed Bearings
2x 50mm Anodised Self-aligning bearing carriers
2x 50mm Anodised Wheel Hubs
Comes with 4x Peg-style Keys
Axle Diameter: 50mm
Axle wall thickness: 2mm
Axle Length: 1030mm
Keyway locations: from end to end (mm) - see picture in 'Detailed Pictures'
A = 20
B = 80
C = 113
D = 173
E = 330
F = 390
G= 730
H = 790
I = 960
J = 1020
K = 1040
Please note that from batch to batch the measurements above may be slightly different
12mm Ventillated 208mm Diameter 6 hole standardised Race PCD.
50mm low friction free-spin bearings
Self-Aligning Bearing Flange/Holder/Cradle complete with 50mm Low Friction Race Bearing installed.
Length: 70mm
SKU AXGTR50
Regular price: $1042.35
Price with FREE DELIVERY: $849.00
