Home :: Axles & Parts :: 40mm :: Complete Axle Kits GT RACE SERIES :: Complete GTR-RACE Series 40mm Axle Kit 12mm Ventillated Disc 8mm Keyway Blue
COMPLETE 40mm AXLE ASSEMBLY including 12mm Ventillated Brake disc (with standardised 6-bolt race hub included).  EVERYTHING you need to bolt-on and go.  Includes ALL the nuts and bolts WITH ANODISED COUNTERSUNK WASHERS!
1x 12mm Ventillated 208mm Brake Disc
Comes with 4x Keys
F = ~296mm
12mm Ventillated 208mm Diameter 6 hole standardised Race PCD.
SKU AXGTR4B
Regular price: $2410.66
