Home :: Axles & Parts :: 40mm :: Shaftless Axle Kits :: GT-RACE Series 40mm Axle Kit Less Brake Disc & Shaft 8mm Keyway Silver
COMPLETE 40mm AXLE ASSEMBLY Without Axle Shaft and Less brake disc (but 6-bolt race hub included).  EVERYTHING you need to bolt-on and go - just add your existing axle shaft and brake disc, or buy your required size from the brake section in the store.  Includes ALL the nuts and bolts WITH ANODISED COUNTERSUNK WASHERS!
NOT INCLUDED.  Kit suits 40mm DIameter Shaft with 8mm Keys.
SKU AXDLSL4S
Regular price: $2193.48
Price with FREE DELIVERY: $349.00
Washer Colour
