Home :: Axles & Parts :: 40mm :: Complete Axle Kits GT RACE SERIES :: Complete GT-RACE Series 40mm Axle Kit Less Brake Disc 8mm Keyway Black
COMPLETE 40mm AXLE ASSEMBLY Less brake disc (but 6-bolt race hub included).  EVERYTHING you need to bolt-on and go - just add your existing brake disc, or buy your required size from the brake section in the store.  Includes ALL the nuts and bolts WITH ANODISED COUNTERSUNK WASHERS!
Comes with 4x Keys
F = ~296mm
BRAKE HUB
Fits Standard Brake Disc PCD - 113.5mm
Fits Standard Brake Disc inner flange 100mm OD.
Keyway size: 8mm
Suits standard 6-Bolt brake disc PCD 113x6 - bolt-to-bolt distance = 56mm
SKU AXDL40K
Regular price: $2319.85
