Home :: Fuel Tanks & Parts :: Fuel Tanks :: Complete External Fuel Tank Relocation Kit Upgrade for 4-Stroke Engines (with GX270/390 Vacuum Sandwich)
*NOTE: Fuel Tank Caps supplied may vary in colour between Black and Red.***
Fuel tank relocation kit with external fuel tank.  Complete kit - this kit contains everything you need to remove your old small on-board fuel tank on your 4-stroke, and replace it with an external steering upright mounted tank.
1x External Fuel Pump (vacuum pulse operated)
1x External 9L Fuel Tank
Capacity: ~ 9L
Dimensions:
Bottom - 23cm x 17cm
Height - 25cm to bottom of cap
Height of retainer button - 18cm
Approx. width of steering uprights at button height (18cm) - approx 75mm (min. inside to inside)
1x Fuel Tank mounting bracket
1x Fuel Tank mounting thumbscrew
2.0m Fuel Line
1x Fuel tank spigot for fuel line entry.
1x Fuel Filter
1x Vac pulse sandwich plate [please note silver vac plate in picture for represtation only - black vac plate as pictured below will be supplied] (for tapping vacuum to connect to vac pump) - suits Honda GX270/390/Predator 420), where hole spacing/venturi is approx:
Dia of holes are 8.4mm (for a 8mm threaded stud) and they are 52mm centre to centre.
Bore/Venturi dia is 28mm
1x Vac Pulse Sandwich Gasket Set
Relocate and increase the size of your tank easily with this complete kit - no more to buy!
SKU FRKC02
Regular price: $1085.00
Price with FREE DELIVERY: $139.95
Vacuum Manifold Sandwich Insulator for External Fuel Pump GX160/200 and Clone
Fuel Tank Spigot Barb Nipple to suit FTKC01
Vacuum Manifold Sandwich Insulator for External Fuel Pump GX160/200 and Clone Fuel Tank Spigot Barb Nipple to suit FTKC01
$34.95
$19.95
