Home :: Wheel, Tyres & Front Hubs :: Rims :: Complete Alloy Dry Slick Rims Set (Bearing Type Fronts) Brand New
BRAND NEW FULL SET of Dry Slick Alloy Rims
Our quality retro-style high-shine bright wheel sets offer impressive design rims and a premium look.
CPR Precision Racing Go Kart Components are designed to provide quality race reliability with unbeatable value.
Our brand new range of alloy rims are quality, round, and precision machined to a high gloss bright polished finish providing a race-worthy wheel with fantastic durability.
REAR
210mm Wide
5" Diameter
PCD: Holes are set 50mm apart from each other and 29mm from the centre
Suit DRY SLICK TYRES.  Wet tyre can be fitted with a little ginning around but will result in slightly smaller diameter wheel.
FRONT
High Speed Low Friction Bearings Installed - 17mm ID - suit 17mm Stub Axles
Offset (inner bearing flange in line with inner rim flange)
130mm Wide
5" Diameter
Outer Bearing Face to Outer Bearing Face = 58mm (this is the amount of the stub shaft this wheel will utilise - spacers will be required to pad out the additional length of your stub shaft)
High Quality turned aluminium alloy.
SKU RSDRSBG
Price with FREE DELIVERY: $295.00
