Home :: Axles & Parts :: 40mm :: Complete 40mm Project Axle Kit 8mm Keyway (Choose your own colours)
THIS KIT ALLOWS YOU TO CONFIGURE ANY COLOUR ANODISED AXLE PART FOR EACH COMPONENT.  YOU CAN CHOOSE ALL THE SAME COLOUR, OR DIFFERENT COLOURS FOR EACH PART YOU LIKE.
IF THE COLOUR YOU WANT FOR A PARTICULAR PART IS OUT OF STOCK, YOU WILL NOT BE ABLE TO ADD IT.
Sometimes we can be out of stock of a specific colour in a particular part (for example, we may be out of red wheel hubs) which will cause the entire red kit to become unavailable.  Using this configurable kit, in the case that all the other components are available in the colour you would like, you can configure the kit for example all red, but with silver or black wheel hubs.
1x 40mm Axle Shaft
Comes with 4x Keys
Axle wall thickness: 3.5mm
F =  ~296mm
SKU AXC408P_KIT
Base product price: $429.00
