Home :: Axles & Parts :: 40mm :: 40mm Axle Kit Less Shaft 8mm Keyway Red
PREMIUM ANODISED RACE KART AXLE KIT
COLOUR AS PER TITLE & PICTURES
*New Model - Suits 2 stroke & 4 stroke kart applications.
BRAND NEW. 40mm AXLE ASSEMBLY. EVERYTHING you need to bolt-on and go less the axle shaft - including ALL the nuts and bolts WITH ANODISED COUNTERSUNK WASHERS!
Just have a look at our feedback - you'll see we care about you and want to ensure that you get excatly what you expect, quickly each and every time. We also go that extra mile for you and ship your goods super quickly. Check out our testimonials - you'll see that our customers are always happy, and always get their stuff fast!
ALSO INCLUDES OVER $75 OF FREE STUFF! - The following nuts, bolts, and fixations:
NOT INLCUDED
SKU AXSLC4R
Regular price: $1345.12
