Home :: Axles & Parts :: 40mm :: Complete 40mm Axle Kit 8mm Keyway Silver (TRAVERS SPEC WITH DISC))
COMPLETE 40mm AXLE ASSEMBLY to TRAVERS SPEC
1x 40mm Axle Shaft
1x 40mm 3-hole proprietary Anodised Brake Hub
F =  ~296mm
Brake Disc Thickness @ 3.5mm
SKU AXCTRAVERS_DISC
Regular price: $2069.86
$24.90
