Home :: Axles & Parts :: 40mm :: Complete 40mm Axle Kit 8mm Keyway Silver (TRAVERS SPEC)
COMPLETE 40mm AXLE ASSEMBLY to TRAVERS SPEC
1x 40mm Axle Shaft
1x 40mm 6-hole Anodised Brake Hub
F =  ~296mm
SKU AXCTRAVERS
Regular price: $2806.32
$29.90
