Home :: Axles & Parts :: 40mm :: Complete 40mm Axle Kit 8mm Keyway Silver PROJECT series with Weld-on Brackets (Race shaft and non-matching keys + peg key)
 *** PLEASE NOTE THIS IS A SPECIAL KIT WITH A DIFFERENT AXLE (LENGTH IS THE SAME BUT ONLY HAS 2 STROKE KEY POSITIONS) - THE KEYS SUPPLIED WILL NEED TO BE FILED DOWN TO SUIT, AND THERE WILL BE  A PEG KEY SUPPLIED TO CREATE YOUR OWN 5TH KEYWAY POSITION)
1x 40mm Axle Shaft
F =  ~296mm
SKU AXC408PS_RS
Regular price: $1427.56
Price with FREE DELIVERY: $929.00
$29.90
