Home :: Axles & Parts :: 40mm :: Complete 40mm Axle Kit 8mm Keyway Silver PROJECT series with Pillow Blocks (With Black Sprocket Hub instead of Silver Sprocket Hub - not pictured)
*NOTE: CUSTOM KIT - this kit has a BLACK SPROCKET HUB instead of a silver one as pictured*
1x 40mm Axle Shaft
2x CPR Pillow Blocks
Comes with 4x Keys
F = ~296mm
PILLOW BLOCKS
DriftTrikeGuideGuide
SKU AXPBC4S_UK
Regular price: $1445.45
$29.90
