Home :: Axles & Parts :: 40mm :: Complete 40mm Axle Kit 8mm Keyway Silver PROJECT series with Weld-on Brackets
1x 40mm Axle Shaft
Comes with 4x Keys
Axle wall thickness: 3.5mm
F =  ~296mm
SKU AXC408PS
Regular price: $1527.21
$29.90
