Home :: Axles & Parts :: 40mm :: Complete 40mm Axle Kit 8mm Keyway Red PROJECT series with Pillow Blocks
1x 40mm Axle Shaft
2x CPR Pillow Blocks
Comes with 4x Keys
F = ~296mm
PILLOW BLOCKS
DriftTrikeGuideGuide
SKU AXPBC4R_U
Regular price: $1445.45
$29.90
