Home :: Axles & Parts :: 40mm :: Complete Racing Mower 40mm Axle Kit 8mm Keyway Gold with Weld-on Brackets and 4-Stud Wheel Adapters Adaptors (WITH BLACK 6mm WASHERS)
*NOTE: SUPPLIED WITH BLACK 6mm COUNTERSUNK WASHERS - not gold as pictured*
1x 40mm Axle Shaft
F =  ~296mm
WHEEL HUB ADAPTERS
SKU AXMP40G
Regular price: $710.75
$29.90
$21.95
