Home :: Axles & Parts :: 40mm :: Complete 40mm Axle Kit 8mm Keyway Gold PROJECT series with Weld-on Brackets (BLACK 6mm WASHERS)
*NOTE: COMES WITH BLACK 6mm COUNTERSUNK WASHERS - NOT GOLD AS PICTURED*
1x 40mm Axle Shaft
Comes with 4x Keys
F = ~296mm
SKU AXC408PG
Regular price: $709.89
$29.90
