Home :: Axles & Parts :: 40mm :: Complete 40mm Axle Kit 8mm Keyway Gold PROJECT series with Pillow Blocks (WITH BLACK 6mm WASHERS)
*NOTE: SUPPLIED WITH BLACK 6mm COUNTERSUNK WASHERS - not gold as pictured*
1x 40mm Axle Shaft
2x CPR Pillow Blocks
Comes with 4x Keys
F = ~296mm
PILLOW BLOCKS
DriftTrikeGuideGuide
SKU AXPBC4G_U
Regular price: $628.13
$29.90
