Home :: Axles & Parts :: 40mm :: Complete 40mm Axle Kit 8mm Keyway Gold (WITH BLACK SPROCKET HUB)
THIS VERSION INCLUDES A BLACK SPROCKET HUB (not gold as pictured)
1x 40mm Axle Shaft
Comes with 4x Keys
F = ~296mm
SKU AXCC408G_KSH
Regular price: $1481.30
$29.90
