THIS KIT ALLOWS YOU TO CONFIGURE ANY COLOUR ANODISED AXLE PART FOR EACH COMPONENT. YOU CAN CHOOSE ALL THE SAME COLOUR, OR DIFFERENT COLOURS FOR EACH PART YOU LIKE. BRAND NEW. Premium CPR Performance Billet Alloy Hubs designed for racing purposes. CPR Precision Race Go Kart Components offer unbeatable value and dependable durability with a design and finish to impress even the fussiest race karters. CPR Race Axle Assemblies have been crafted to suit high horsepower, high G-Force racing - both dirt and bitumen. Our kits are the perfect replacement for damaged or worn rear axle assemblies, or to upgrade an older or smaller setup to meet modern demands. Not only are CPR Race Axle Assemblies high quality, but they also represent outstanding value for money. When you replace or add a CPR kit, you'll have access to replacement parts at unbeatable value into the future. This is the new model. It suits 2 stroke and 4 stroke karts.
COMPLETE 40mm AXLE ASSEMBLY. EVERYTHING you need to bolt-on and go - including ALL the nuts and bolts WITH ANODISED COUNTERSUNK WASHERS!
INCLUDES: 1x 40mm Axle Shaft 1x 40mm Anodised Brake Hub 1x Drilled Brake Disc 1x 40mm Anodised Sprocket Carrier/Hub 2x 40mm Low Friction Sealed Bearings 2x 40mm Anodised Self-aligning bearing carriers 2x 40mm Anodised Wheel Hubs
PLUS ALSO INCLUDES the following nuts, bolts, and fixations: 4x Axle Keys cut to fit exact lengths of keyways 3x Bolts, washers & 2x Square Head High Tensile bolts for Brake Hub 6x ANODISED Countersunk Washers, 6x Countersunk High Tensile bolts, 6x Washers, 6x Nyloc nuts, 2x High tensile bolts for Sprocket Carrier 6x ANODISED Countersunk Washers, 6x Countersunk High Tensile bolts, 6x Washers, 6x Nyloc nuts, 2x High tensile square head bolts and 2x nuts for Bearing Carriers. 6x Studs, 6x Washers, 6x Nylocs, 2x High Tensile Square Head bolts for Wheel Hubs.
Comes with 4x Keys
Axle Diameter: 40mm Axle wall thickness: 4.5mm Axle Length: 1047mm (~1050mm) Keyway width: 8mm Keyway locations: from end to end
A = 1047mm (~1050mm) B = ~10mm C = ~65mm (Keyway position from end of shaft ~10mm -> ~75mm) Please note from batch to batch the measurements above may be slightly different.
BRAKE DISC Brake Disc Thickness @ 4.5mm Brake Disc Diameter @ 190mm
BEARINGS 40mm low friction free-spin bearings
BEARING CARRIERS Self-Aligning Bearing Flange/Holder/Cradle complete with 40mm Low Friction Race Bearing installed. Holes are set 78mm apart from each other and 45mm from the centre. Thickness of hanger is 20mm (5mm per side can be removed if required by linishing/filing/cutting for thin hanger brackets) Height from bottom of hanger to top of hanger total 110mm
WHEEL HUBS 8mm Keyway Length: 60mm PCD 50mm x 3 (Holes are set 50mm apart from each other and 29mm from the centre - Suit Standard Rear Wheels). Studs, washers & nuts included - standard thread SPROCKET HUB 8mm Keyway Holes are set 67mm apart from each other and 67mm from the centre (Suit Standard 219 or 35 pitch Sprocket). PCD Diameter = (6x) 132mm (centre of 6mm holes on opposite sides of sprocket) Suits standard kart sprockets (Inner Sprocket Diameter 116mm)
Brand New |
| SKU | AXCC408_KIT | |
| Base product price: |
$399.00
including GST 10% |
