Home :: Axles & Parts :: 40mm :: Complete 40mm Axle Kit 8mm Keyway Blue (WITH SILVER BEARING HANGERS)
**THIS MODEL COMES WITH SILVER BEARING HANGERS - NOT BLUE AS PICTURED **
1x 40mm Axle Shaft
Comes with 4x Keys
F = ~296mm
SKU AXCC408B1
Regular price: $1483.97
$29.90
