Home :: Axles & Parts :: 40mm :: Complete 40mm Axle Kit 8mm Keyway Black PROJECT series with Weld-on Brackets
1x 40mm Axle Shaft
Comes with 4x Keys
F = ~296mm
SKU AXC408PK
Regular price: $1527.21
$29.90
