Home :: Axles & Parts :: 40mm :: Complete 40mm Axle Kit 8mm Keyway Black PROJECT series with Weld-on Brackets (with oversize 40mm shaft)
1x 40mm Axle Shaft
F =  ~296mm
SKU AXC408PK1
Regular price: $1410.34
$29.90
