Home :: Axles & Parts :: 40mm :: Complete 40mm Axle Kit 8mm Keyway Gold (WITH BLACK 6mm WASHERS)
*NOTE: SUPPLIED WITH BLACK 6mm COUNTERSUNK WASHERS - not gold as pictured*
1x 40mm Axle Shaft
Comes with 4x Keys
F = ~296mm
SKU AXCC408G
Regular price: $654.16
$29.90
