Home :: Axles & Parts :: 40mm :: Complete 40mm Axle Kit 8mm Keyway Black
1x 40mm Axle Shaft
Comes with 4x Keys
F = ~296mm
SKU AXCC408K
Regular price: $1482.34
$29.90
